part compare (features) with protoolkit
cosimo90
3-Newcomer
hi, it's possible compare two parts with pro/toolkit?
I need to know if they have the same features.
Thanks.
Just same features or geometry also?
You can traverse through features and compare ID of feature along with feature type with similar details obtained for another part.
It becomes more difficult to verify geometry of both parts for all features.
AFIK, there is no such provision for two part comparison. One can get revision stamp of part / feature in a part to identify whether it has been updated or not.
Let's wait for more responses. I am also looking for the comparison of two parts.
We have code for this! Email me at Phil.clukies@Cadactive.com to learn more.
Thanks.
I solved by calculating the intersection between 2 prt and comparing the volume of the intersection with the volume of the prt
Great to know that you solved this.
calculating the intersection between 2 prt : did you mean to say that you assembled both parts temporary and found interference?
