https://www.ptc.com/en/support/article/CS276430 . Already tried with this solution, but still no luck
Thanks.
Yes, I fixed it. In API "ProDrawingFromTmpltCreate" argument "PRODWGCREATE_DISPLAY_DRAWING" changed to "PRODWGCREATE_WRITE_ERRORS_TO_FILE" has solved this
I'm not familiar with Toolkit, but should this code reference the drawing view, and not the new drawing for the BOM balloons?
I guess you have it already fixed, but the drawing must be displayed in a Window.
