reading tolerance info using jlink
StephenHaberman
I am trying to use jlink to read dimension information from proe file, including tolerances.
I get the model, get the features, get dimensions for the feature, and get tolerance from dimension.
In sample files like the blower that comes with web toolkit it works fine, but on actual production models that I have, no tolerance object seems to be there. I explicitly set the upper and lower using proe and I can close and re-open file so I know they are there, still cannot find them with jlink....
any ideas??
Steve
0 REPLIES 0
