working directory on startup?
erine
I would like to startup CP 3.0/4.0 and automatically be in a specific working directory drive instead of C:\Prostart (We currently do not use a PDM server). I can't find any setting in my config that drives the current location to C:\Prostart.
Does anyone know of a setting in config that will allow this?  Just FYI, I know that you can set it manually by right-clicking.
Thank you!
Creo 4.0 / M060
TomU
(To:erine)
Your initial working directory is based on your start in location.  This can be controlled by the shortcut used to start or it can be manually set by a .bat file.
If you want to force Creo to always open files from a particular location, take a look at the config option file_open_default_folder.
TomU
(To:erine)
