How to get 2 different possitions of an assembly on 1 drawing.
chris5
Hi there
I made a design of a tipper. In asm the tipper can open and close (manually) and the backdoor kan open and clos 2 ways.
On my drawing I want to show it closed as in the pdf in the attach file but on the same page In open condition.
How do I do that. With relations I have never worked before. So I need a large explain.
Regards
Chris
Canopys
(To:chris5)
Hi, of what I know, you can do this with a snapshot when using mechanism. But as you used relationship to move your assembly, I don't know if it is possible.
http://communities.ptc.com/message/10705#10705
chris5
(To:Canopys)
Hi Max
I thank you, now I have found it, then you can import it in the drawing as a kind of exploded view.
See my result in the attachement.
Hot greetings from Belgium (35°C)
Problem solved.
