Missing Dimensions from Printed Drawing
bshepherd
Since updating to Creo 3 M40 we have been having trouble across almost all drawings with dimensions not being printed. About 50% of the time, some (not all) dimensions are missing from the page when printed.  They are visible in the drawing in the creo window but do not show on the page when printed or when creating a pdf (using CutePDF printer).  If we just print the same drawing again (without doing anything; no regen, no update) the missing dimensions are often printed.  This is very frustrating and dangerous.  Has anyone else had this problem.
1 ACCEPTED SOLUTION
Ben,
You may try this in M050 datecode, I had the same issue which was reproducible in M040 however not in Creo 3.0 M050.
5 REPLIES 5
Ben,
It will be a few days before I can try this.  I will let you know if it works for me.
We have been using M50 for about a week and no one has had any more issues.  Thank you.
Good to know that everything is working correctly. Thank you.
Never had this iusse. I do not use any exteral program to generate pdf anyway. Strange....
I think it's because i don't use snap lines for dimensions
