Anyone could you please tell me, How to add a Dimension parameter as a driving dimensional value in flexibility constrain dialogue box.
If you are talking about a flexible model in the assembvly tree, then you can create a relation in the assembly and use that as a value in the dialog.
Hello Ramesh, was Antonius' comment the Correct Answer for you? Then please close the thread by marking his post as such. Or, if you had something else in mind, provide a little more details on what you try to achieve. Finally, if you have found an answer to your question yourself, please share it with us. Thanks, Gunter
