Delete a row from a table
SOLVED
Highlighted
Participant
I need  to remove a row from a table I have already created.  I am able to delete contents but where is the delete row?
I also have a flag note in between to defined dimensions but need to either add a leader or be able to have arrows on each side of the flag note.  I tried creating a dimension so I will have the arrows and then deleting the dimension text but the text comes back.  What are my options?
See images below.
1 ACCEPTED SOLUTION
Highlighted
Re: Delete a row from a table
1.] row deletion
  • set selectionfilter to Table Row
  • select row
  • press right mouse button
  • use Delete command
2.] flag note
  • create drawing dimension
  • set text height to 0.01 mm (dimension value is not visible now, arrows remain visible)
MH
Martin Hanák
6 REPLIES 6
Highlighted
1.] row deletion
  • select row
2.] flag note
MH
Martin Hanák
Highlighted
Where do I find Selection Filter?  What table is that under.  I do not see it under the table tab.
The cheating for the flag note worked great.  I like it.
Highlighted
Selection Filter combo box is located at the bottom right corner of Creo windows.
MH
Martin Hanák
Highlighted
Perfect.  Thank you VERY much for the prompt help.
Highlighted
Don't forget to mark Martin's answer as correct for those who may search on the topic later.
Highlighted
Hello MartinHanak,
Your detailed explaination helped me alot,Thanks..It's working exactly what I intended to be..Thanks
Tags (1)
