Good morning/afternoon/evening all.
Is there an easy way to fake a linear dimension in Detailing (WF5)?
We have a component that consistently swells in molding and the manufacturing facility wants to change the print nominal to match this condition.
I do not want to change the model because two or three years from now when we replace the tooling, everybody will forget the fake and build the tool to the changed model.
Thanks in advance.
Eric Mills
Design and Project manager
http://www.rapidoconsulting.com
eric.mills@rapidoconsulting.com
I think if I was doing it I would simply add text to the dimension. Something like XX.XX (SWELL DIMENSIONXX.XX) or something to that extent instead of changing the dimension and risking some sort of catastrophe in the years to come.
Eric Mills
