There is a block over the title block containing the company name/logo and I need to edit this infomation.
edit the drawing format
open the .frm and edit accordingly
ron
Is it in a symbol that is called and placed on the format?
You will need to do the edit at the format level, not the drawing level.
You probably have a format file for the title block. Look for the .frm file. You can open the format and edit it.
