Is it possible to copy from excel to drawing table?
ppandarkar-2
Hi..
Is it possible to copy data from excel to drawing table as below,
Prashant pandarkar
5 REPLIES 5
Save Excel table as CSV.  Select Table From File, change Type to CSV and locate saved CSV.
ppandarkar-2
(To:kdirth)
Hi..
I want to copy only one column, because my half table is repeat region and half is editable.
so i want to copy only one column from excel to creo drawing.
.csv method already tried but we can not maintain repeat region in .csv method.
Prashant Pandarkar
I do not believe there is a way to combine tables.  You will need to manually cut and paste text from excel into individual table cells.
split your table into two ones - 1st table containing repeat region, 2nd table containing editable information. Align table borders to simulate "one table".
MH
Martin Hanák
A repeat region is dynamically synchronized with the model data, but the spreadsheet information isn't.
It would be easier to add repeat region relations and a repeat region parameter instead of doing that work in Excel and trying to join the data later.
