Doug,
Try search by component with rule set to name.
jef
In Reply to Doug Barton:
Hi all
I'm trying to use the Search Tool to find an ECAD component by the
ECAD_REF_DES parameter, but I can't figure it out. There are other ECAD
parameters I can search on but not ECAD_REF_DES (Search Tool doesn't seem
to know it exists). Anyone know if this is possible and how to set up the
Search Tool to do it?
Also, and I just thought of this but haven't tried it yet, would it be
possible to use ECAD_REF_DES in a table repeat region (to show a BOM with
reference designators included)?
WF4
Doug Barton
Mechanical Designer
Parker Hannifin Canada
Electronic Controls Division
1305 Clarence Avenue
Winnipeg, MB R3T 1T4 Canada
direct 204 453 3339 x7309
fax 204 452 7156
www.parker.com/ecd
"PLEASE NOTE: The preceding information may be confidential or
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
