AFX should be establish the project name and support the named parts/assemblies one by one
but there is a large problem in efx/equipments.
project_name=1420 ,
the named stair assemlby: NF1420_STAIR_1_1
the named stair parts: NF1420_ U_BEAM_1_L1_1 ,and so on;
So I can create the element_name.txt in \efx\parts\equipment\steel_construction_mm\stairs ,
The content :PROJECT_SHORT#_#ELEMENT_NUMBER
now
project_name=1420 ,
the named stair assemlby: NF1420_1;
the named stair parts: NF1420_ 2;
NF1420_3 ,and so on;
These named parts/assemblies are not my named code;
so I need a named code ,for example:
project_name=1420 ,
the named stair parts: NF1420_ 1-1;
NF1420_1-2 ,and so on;
I need help from buw and tell me the named code .
THANKS !
seems the only thing you are missing is to replace the "_" by a "-". If this is correct just replace
#_# by #-# in file element_name.txt
Stefan
hello,stefan
You still haven't answered my question.
These are correct by used "_"or"-" in file element_name.txt
there are no problem,look at the picture above.
how to create the named code one by one in afx/equipments.file ?
you can put
SUBASSEMBLY_NAME#-#ELEMENT_NUMBER
into element_name.txt and set option , but then the files will be named like
NF1420-1-2
I do not know in what cases you make "-" and in what cases you make "_" between the numbers
Stefan
hello,
these are very good now .
1.when I set the element SUBASSEMBLY_NAME#_#ELEMENT_NUMBER
2.when I set the element SUBASSEMBLY_NAME#-#ELEMENT_NUMBER
Usually, we are used to design a assembly by "_",
so we are used to design a part by "-",
now we hope to create the code of model tree
for example:
project_name=NF1500_1 ,
the named stair assemlby: NF1500_1_1;and so on
but the named stair parts: NF1500_1_1-1;
NF1500_1-1-2 ,and so on;
Stefan, Can we do it ?
Thanks you very much!
you can have different element_name.txt files for parts and assemblies.
Besides the file element_name.txt create a file element_name_asm.txt which contains different naming scheme.
Then AFX will use element_name.txt for naming parts and element_name_asm.txt for naming assemblies.
Maybe this helps
Stefan
Thanks,Stefan
The naming scheme is very perfect!
I set the element_name_asm.txt "PROJECT_SHORT#_#ELEMENT_NUMBER“
yet set the element_name.txt "SUBASSEMBLY_NAME#-#ELEMENT_NUMBER“
now create the naming model tree.
but when I set the element_name_asm.txt "SUBASSEMBLY_NAME#-#ELEMENT_NUMBER“
yet set the element_name.txt "SUBASSEMBLY_NAME#-#ELEMENT_NUMBER“,
so to create the same naming model tree!
Are these difference between two naming element.txt ?
hi,stefan
But this naming scheme is only for one assembly
If we can establish a assembly contain some subassemlies and some parts.
For example:
project_name=NF1600
the first named assembly: NF1600_1
the second named assebly: NF1600_2
and so on ……
but the first assembly:NF1600_1 contains some subassemlies and some parts.
the first named subassembly : NF1600_1_1
the second named subassembly : NF1600_1_2
and so on ……
also the first assembly have some parts
the first named part: NF1600_1-1, [ belong to the first assembly:NF1600_1 ]
the second named part: NF1600_1-2, [ belong to the first assembly:NF1600_1 ]
can we do to creating this naming scheme ?
THANKS!
please try to set element_name_asm.txt to
Stefan
now I set a assembly in the file D:\Program Files\PTC\Creo 2.0\Common Files\M100\efx\parts\equipment\steel_construction_mm\steel_design\nf1210_1_30gg.asm
This assembly contains some subassemblies,and these subassemblies contains some sub-subassemblies and some part.
I set the element_name.txt "SUBASSEMBLY_NAME#-#ELEMENT_NUMBER“ in the file.
The naming scheme is now appearing in the picture above.
how to do it?
thank you,stefan
sorry, I do not understand
- what you mean by "now I set a assembly in the file D:\Program Files\PTC\Creo 2.0\Common Files\M100\efx\parts\equipment\steel_construction_mm\steel_design\nf1210_1_30gg"
- what assembly the model tree shows
- in what folders you set the element_name.txt and element_name_asm.txt
=> I need more detailed information to check what exactly you want to do
Stefan
the model tree of this assembly shows as the picture
project_name=NF1210_1_30GG
the first named assembly: NF1210_1_30GG_1
the second named assebly: NF1210_1_30GG_2
and so on ……
but the second assembly:NF1210_1_30GG_2 contains some subassemlies and some parts.
the first named subassembly : NF1210_1_30GG_2_1
the parts of the first named subassembly: NF1210_1_30GG_2_1-1
NF1210_1_30GG_2_1-2
NF1210_1_30GG_2_1-3
the first named part : NF1210_1_30GG_2-1 [ belong to NF1210_1_30GG_2 ]
the second named part : NF1210_1_30GG_2-2 [ belong to NF1210_1_30GG_2 ]
and so on ……
I set the element_name.txt and element_name_asm.txt in this file D:\Program Files\PTC\Creo 2.0\Common Files\M100\efx\parts\equipment\steel_construction_mm\steel_design
I use the element_name_asm.txt for assemlies ( set the code:SUBASSEMBLY_NAME#_#ELEMENT_NUMBER )
yes ues the element_name.txt for parts (set the code:SUBASSEMBLY_NAME#-#ELEMENT_NUMBER )
I am used to the character "_" for assemlies and used to the character "-" for parts.
can we establish this naming scheme?
I think you need to send me your models and all other files required to see the issue here on my computer for further investigation. If you send data to see the problem to stefan@buw-soft.de then I will do further investigations
Stefan
