vessel design, man hole, nozzle
Re: vessel design, man hole, nozzle
hi visu
i m also involved with boiler vessels and nozzles (cylinderical, spherical, elipsoidal dishes,etc)
it involves only simple extrude or revolve, no need of assembly
1. make the base vessel by extrude or revolve
2. make a datum plane parallel to the axis of the base vessel at the specific height
3. then with this datum plane as the sketching plane extrude until next or selected(surface) option
you will get a nozzle surface merged with the vessel surface
like this you can cut a dish(for nozzle) from the vessel or make a cut in the base vessel for the recieving nozzle also
