Azure Connector 4 Part 2
- November 2, 2022
- 0 replies
- 347 views
- Step 4: Launch IoT Hub Connector
- Step 5: Import Device from Azure
- Step 6: Set-up and Run Demo
- Step 7: Next Steps
- Open a shell or a command prompt window. On a Windows machine, open the command prompt as Administrator.
- The AZURE_IOT_OPTS environment variable must be set before starting the Azure IoT Hub Connector. Below are sample commands using the default installation directory.
- On Windows: set AZURE_IOT_OPTS=-Dconfig.file=C:\ThingWorx-Azure-IoT-Connector-<version>\azure-iot-<version>-application\conf\azure-iot.conf -Dlogback.configurationFile=C:\ThingWorx-Azure-IoT-Connector-<version>\azure-iot-<version>-application\conf\logback.xml
- On Linux: export AZURE_IOT_OPTS="-Dconfig.file=/var/opt/ThingWorx-Azure-IoT-Connector-<version>/azure-iot-<version>-application/conf/azure-iot.conf -Dlogback.configurationFile=/var/opt/ThingWorx-Azure-IoT-Connector-<version>/azure-iot-<version>-application/conf/logback.xml"
NOTE: You must run the export command each time you open a shell or command prompt window.
- Change directories to the bin subdirectory of the Azure IoT Hub Connector installation.
Start the Azure IoT Hub Connector with the appropriate command for your operating system.
- On Windows: azure-iot.bat
- On Linux: /azureiot
NOTE: On Windows you may have to shorten the installation directory name or move the bin directory closer to the root directory of your system to prevent exceeding the Windows limit on the classpath length.
- The Connection Server should start with no errors or stack traces displayed. If the program ends, check the following:
- Java version is 1.8.0, update 92 or greater and is Java(TM) not OpenJDK
- Open azure-iot.conf and confirm ThingWorx Foundation is set to the correct URL and port.
- Confirm the platform scheme is ws if http is used to access ThingWorx.
- Confirm all Azure credentials are correct for your Azure account.
- In ThingWorx Foundation click the Monitoring tab then click Connection Servers. You should see a server named azure-iot-cxserver-{server-uuid}, where {server-uuid} is a unique identifier that is assigned automatically to the server.
With the ThingWorx Azure IoT Connector, you can import into ThingWorx any existing devices that are currently provisioned to the Azure IoT Hub.
Add Device Azure IoT Hub
If you have not provisioned any devices to your Azure IoT Hub you can learn more about Azure IoT Hub device identity before following the steps below to create a test device.
- In your Azure Portal, click All Resources, then select the name of your IoT Hub.
- Under Explorers click IoT devices, then click + Add.
- Enter a name for your device, then click Save
- When the device name appears in the list it is ready to us
Import Device into ThingWorx
We will manually execute a service in ThingWorx that will import Azure IoT Hub devices into ThingWorx.
In ThingWorx Composer, navigate to the ConnectionServicesHub Thing.
Click Services tab and scroll to the ImportAzureIotDevices service and click the execute Arrow.
NOTE: The * in the pattern field will act as a wildcard and import all devices, you can enter a string to match that will only import a subset of all available devices.
- Click Execute to import the devices then click Done.
- Click Things in the left column to see the Things that were created.
The ThingWorx Azure IoT Connector download includes a Java application that simulates a device connecting to your Azure IoT Hub. A ThingTemplate is also included and can be imported into ThingWorx.
Import Demo Templates
In ThingWorx Composer, click Import/Export menu, then click From File and browse to ../demo/edgedevice- demo/platform/entities/CPUDemo_AllEntities.xml
- Click Import then click Close when the import successful message is displayed.
- Create a new Thing using the imported template azureDemo1, enter a name for your Thing and click Save.
NOTE: You will enter this name in the demo config file in the next step.
Configure Demo Application
- In the ../demo/edge-device-demo/conf subdirectory, open the edge-device.conf file with a text editor.
- Edit the deviceId to be the name of the Thing you created in step 3.
- Edit the iotHubHostName to use the name of your hub plus the domain: azure-devices.net. For example, sample-iot-hub.azuredevices.net.
- Edit the registryPolicyKey property to use the Primary Key for the registryReadWrite policy in the Azure IoT Hub.
Below is an example configuration:
// Azure Edge Device Demo configuration azure-edge-device { // Name of the remote thing on the ThingWorx platform, which should match the Azure Device ID deviceId = "alstestedgething" // Name of the hub host in Azure iotHubHostname = "alsiot.azure-devices.net" // Policy name used by this thing (could require services as well in future) registryPolicyName = "registryReadWrite" // The Key related to the policy above registryPolicyKey = "pzXAi2nonYWsr3R7KVX9WuzV/1234567NZVTuScl/Kg=" }
Run Demo Script
- Open a shell or Command Prompt, set the EDGE_DEVICE_DEMO_OPTS environment variable to refer to the file you just edited:
- Linux - export EDGE_DEVICE_DEMO_OPTS="-Dconfig.file=../conf/edge-device.conf"
- Windows - set EDGE_DEVICE_DEMO_OPTS="-Dconfig.file=../conf/edge-device.conf"
- Launch the demo from the ../demo/edge-device-demo/bin subdirectory, using the edge-device-demo command.
- Return to the ThingWorx Composer and open the Properties page of the Azure Thing that you created previously.
- Click the refresh button to see the properties change every five seconds.
- Open the azure-iot-demo Mashup and view the Load Average and CPU gauges, and the increases in the values of the Cycle and Uptime fields.
NOTE: If the edgedevice-demo is running on Windows, the Load Average does not register.
Step 7: Next Steps
Congratulations! You've successfully completed the Connect Azure IoT Hub to ThingWorx Quickstart. By following the steps in this lesson, you imported a device created in Azure into ThingWorx and saw how data from an Azure device could be used in a ThingWorx Mashup.
Learn More
We recommend the following resources to continue your learning experience:
| Capability | Guide |
| Connect | Choose a Connectivity Method |
| Build | Design Your Data Model |
| Experience | Create Your Application UI |
Additional Resources
If you have questions, issues, or need additional information, refer to:
| Resource | Link |
| Community | Developer Community Forum |
| Support | Getting Started with ThingWorx |
