Jul 26, 2022 8:05 PM UTC
Basic Mashup Widgets Guide Part 3
Step 5: Gauge
A Gauge is best for displaying a quickly readable approximate value.
  1. Select the Widgets tab in the uppper panel of the left dock, then enter gauge inside the Filter field in the top left.
  2. Drag-and-drop the Gauge widget onto the bottom-center container.
  3. We will now bind the Slider to the Gauge. Click the Slider Widget in the top-right Container.
  4. Click the drop-down arrow on the left side of the Slider widget.
  5. Click and drag the Value property listed in the Slider drop-down onto the Gauge widget.IoTProductMgmt_21-1658761869162.png
  6. Click the # Data property that is available from the Select Binding Target pop-up.IoTProductMgmt_22-1658761869165.png
  7. Click Save to save your Mashup.
  8. Click View Mashup then adjust the slider to the left to see the changing value shown on the widget.
Many properties are available that give control over how the Gauge widget will be displayed. Many properties can be changed both statically when designing the mashup, and dynamically in response to changes in property values.
Bindable
Name
Type
Default
Direction
Description
Data
Number
None
Input
Value displayed by gauge indicator
MinValue
Number
0
Input
Value used for lowest gauge display
MaxValue
Number
100
Input
Value used for highest gauge display
Legend
String
None
Input
Text Shown under Gauge
ToolTipField
String
None
Input
Text shown when mouse hovers over gauge
Visible
Boolean
True
Input
Widget is visible if set to true
Static
Name
Type
Default
Description
DisplayName
String
None
Name used for widget in user-facing interactions
Description
String
None
Description used for widget in user-facing interactions
MinorTicks
Number
4
Number of minor ticks per interval
TickLength
Number
8
Tick mark length
MinorTickLength
Number
4
Minor tick length
ValueDisplayMode
None/Top/Bottom/Inside
None
Location on gauge where numeric value is shown.
LabelDigits
Number
3
Number of digits for label display
LabelDecimals
Number
0
Number of decimals for label display
ValueDigits
Number
3
Number of digits for value display
ValueDecimals
Number
0
Number of decimals for value display
LegendDisplayMode
None/Top/Bottom
None
Location on gauge where Legend is displayed
ReferenceAngle
Number
225
Angle that controls the gauge orientation (degrees)
Aperture
Number
270
Angle that controls the gauge size (degrees)
NeedleDiameter
Number
10
Diameter of the gauge needle (pixels)
CenterDiameter
Number
20
Diameter of the gauge center (pixels)
GaugeBorder
Number
20
Width of the outside gauge border (pixels)
Step 6: Grid Advanced
A Grid Advanced widget is used to display data to a mashup user in a table
  1. Select the Widgets tab in the uppper panel of the left dock, then enter grid inside the Filter field in the top-left.
  2. Drag-and-drop the Grid Advanced widget onto the top-left container on your Mashup that already has the Button Widget.
Add Data Source
Before you can customize the Grid display, you must first bind an Infotable to the Grid's Data property. In this example we will use the QueryImplementingThingsWithData Service to bind a group of Things created with the same Template.
We have created a file with sample entities for this exercise.
  1. Download the attached demoTractors.xml.
  2. Click Import/Export in the lower left of Composer, then select ImportIoTProductMgmt_25-1658761869182.png
  3. Click From File in the drop down, then Browse.
  4. Browse to the demoTractors.xml file and click Open.
  5. Click Import, then Close after entities are successfully imported.
  6. Click the green + button in the Data tab on the right side of the Mashup Builder window.
  7. In the Select Entity panel click Thing Templates from the drop down.IoTProductMgmt_26-1658761869183.png
  8. Scroll through the available Thing Templates and select the Connected Tractors Template that was imported.
  9. Enter query into the filter text box then click the arrow to the right of QueryImplementingThingsWithData.
  10. Click the Execute on Load check box, this option will execute the QueryImplementingThingsWithData Service when the Mashup is loaded.IoTProductMgmt_27-1658761869184.png
  11. Click Done.
  12. Click the arrow icon to expand QueryImplementingThingsWithDate, and Returned Data.
  13. Click and drag All Data onto the Grid widget.IoTProductMgmt_28-1658761869186.png
  14. Click Data in the Select Binding Target pop-up.IoTProductMgmt_29-1658761869190.png
NOTE: The Grid widget now shows Property names in the column headers.
15. Click the drop down in the upper left of the Grid widget, then click Configure Grid Columns to show the Configure Grid Columns pop-up.
16. Uncheck the check box next to the property names in the left-hand panel that you don't want shown in the Grid.
NOTE: You can drag and drop the property names to change the display order. You can customize Column names and formatting by making changes in this window.
17. Click Done when you are satisfied with the column formatting options.
18. Click Save to save your Mashup.
19. Click View Mashup.
In addition to properties that give control over how a Grid widget will be displayed, the scroll position of a Grid can be read in the CurrentScrollTop property and can be set with the ScrollTop property.
Bindable
Name
Type
Default
Direction
Description
Data
Infotable
None
Input
The data that is displayed in the Grid
EditedTable
Infotable
None
Output
The data that is in the Grid after a user edit
CurrentScrollTop
Number
0
Output
How far down (in pixels from the top of the full data list) the Grid is currently scrolled
ScrollTop
Number
0
Input
How far down (in pixels from the top of the full data list) the Grid will be scrolled.
Visible
boolean
true
Input
Static
Name
Type
Default
Description
DisplayName
String
None
Name used for widget in user facing interactions
Description
String
None
Description used for widget in user facing interactions
RowFormat
StateDefinition
None
Specify a State Formatter to control display of the data in each grid row
AlignHeader
Boolean
False
When enabled, align column headers with their data
MultiSelect
Boolean
False
allow multiple items to be selected
IsEditable
Boolean
False
Allow grid value editing in Configure Grid Columns pop-up
AutoSelectFirstRow
Boolean
False
Automatically select the first row upon initial loading of data.
CellTextWrapping
Boolean
False
Enable or disable text wrapping within the grid cells.
TabSequence
Number
0
Tab sequence index
Widget Events
Name
Description
DoubleClicked
Fired when user double clicks on the grid
Step 7: Next Steps
Congratulations on completing the guide!
The next guide in the Customize UI and Display Options to Deploy Applications learning path is Define Your UI Style.
If you have questions, issues, or need additional information, refer to:
Resource
Link
Experience
ThingWorx Application Development Reference
Community
Developer Community Forum
Support
Button Widget Help Center
Support
Slider Widget Help Center
Support
Gauge Widget Help Center
Support
Advanced Grids (Themable) Help Center
