Customize UI and Display Options to Deploy Applications Learning Path
Build, customize, and deploy IoT applications with ThingWorx.
NOTE: Complete the following guides in sequential order. The estimated time to complete this learning path is 270 minutes.
1. Create Your Application UI
2. Basic Mashup Widgets
3. Define Your UI Style
4. Object-Oriented UI Design Tips
5. Deploy an Application
6. How to Display Data in Charts
