Explore the ThingWorx Foundation IoT application-building platform in a convenient video format.
This project will introduce you to the principles of ThingWorx Foundation by creating a working web application, guided by a convenient video.
Following the steps in this guide, you will create the building blocks of your first application for the Internet of Things (IoT). You will use ThingWorx Composer to create Thing Templates, which are then used to create Things that model the application domain. A simulator is imported to generate time-series data that is saved to a Value Stream.
After modeling the application in ThingWorx Composer, you'll use Mashup Builder to create the web application Graphical User Interface (GUI).
NOTE: The estimated time to complete this guide is 30 minutes
Click the link below to enjoy the video.
Get Started with ThingWorx for IoT
Congratulations! You've successfully completed the Get Started with ThingWorx for IoT Video Guide, and learned how to:
We recommend the following resources to continue your learning experience:
Capability Guide
Connect | Choose a Connectivity Method |
Build | Design Your Data Model |
Experience | Create Your Application UI |
If you have questions, issues, or need additional information, refer to:
Resource Link
Community | Developer Community Forum |
Support | Getting Started with ThingWorx |
