Nov 30, 2022 10:00 PM UTC
Using an Allen-Bradley PLC with ThingWorx Learning Path
- 0 replies
- 2305 views
- Translate All
Use Rockwell Automation's Connected Components Workbench to connect an Allen-Bradley PLC for use with the ThingWorx Platform. This Learning Path will guide you through installation of Rockwell Automation and ThingWorx applications, connecting ThingWorx to the Allen-Bradley PLC, and how to configure, monitor, and control the PLC from ThingWorx.
NOTE: Complete the following guides in sequential order. The estimated time to complete this learning path is 240 minutes.
This learning path assumes that ThingWorx has already been installed
1, Install Rockwell Connected Components Workbench
2. Install ThingWorx Kepware Server
3. Connect to an Allen-Bradley PLC
6. Visualize an Allen-Bradley PLC
