Hi
in KepServerEX6 I created a channel ODBC Client to get data from a Access database.
I created a Device for a table and successfully generated a tag.
Now I would like to get data from other tables.
I created another device (correct ? ) but the tag generation return error "Unable to generate a tag database for <MY DEVICE>:Automatic tag generation for device <MY DEVICE>' refused due to active client connections"
I read another topic , same error. The suggestion was to 'Close all OPC client connections to the device and retryAutomatic Tag Generation' but how can I verify the open connections and close them ?
Many Thanks
DSN does not allow you to create connection as it shows already in use on same channel. We recommend to create a separate channel with new device and try to generate tags.
