I have this error : Device is not responding. | ID='xxxx(ip of the machine)' but when i launch Quick Client i can see data coming from tags. Anyone can help me with this ? I'm using ThingWorx Kepware Server 6 and this is happening only for machines that use Siemens TCP/IP Ethernet protocol
Greetings @Lo_ry96 ,
I hope you are doing well.
I would like to inform you that the cause of this error "Device is not responding" might be communication is blocked between networks.
Kindly follow the below steps to address this issue.
If you continue to experience issues, I recommend opening a support ticket with the Kepware Technical Support team. Here is a link to the my kepware login page where a ticket can submitted:
