‎Dec 06, 2023 01:43 AM
How to connect OPCDA - InTouch (HMI) via KepServer EX as an OPC server
1 ACCEPTED SOLUTION
‎Dec 06, 2023 02:28 AM
Re: How to connect OPCDA - InTouch (HMI) via KepServer EX as an OPC server
InTouch has its own I/O Server to connect to other PLC, but sometime you still need to read/write data from/to an OPC server. By using Kepware OPC server, it's easy to read or write data whitin InTouch. This screencast is showing you how to create connection between InTouch and Kepware OPC server.
‎Dec 06, 2023 10:46 PM
‎Dec 28, 2023 08:58 AM
