I need to a counter tag in Kepware which accumulates up every time another tag goes from 0 to 1. What is the best approach in Kepware for this? I have the advanced tag plugin
Unfortunately, the core functionality of KEPServerEX/ThingWorx Kepware Server is not designed to perform counter operations. Attempting to do so may not guarantee accuracy. Typically, this type of logic is performed in PLCs.
Thank you for your understanding.
