We installed KEPServerEX 6.14.263.0 on a customers VM last year and they now say it's getting flagged by their antivirus software. Not sure what they are using but wondering how often this happens and if installing the latest version will help?
Please take a look at the Kepware knowledge base article in the following link. It shows the vulnerability you have mentioned was recognized and addressed in the latest release of KEPServerEX (v6.15)
Article - CS397286 - Security vulnerability identified in PTC Kepware Products - CVE-2023-3825
*Chris
I have zero idea if this is related - you would have to provide more details regarding exactly what CVE the AV is flagging, But I have an unrelated software package I have to update yearly that I can't download this year because Sophos AV targets the following GIF vulnerability contained in the package.
The odd part is that this vulnerability is from 2013 so why has it not been flagged by my AV till now?
No idea if this helps, but at least you are not alone
This is the vulnerability they flagged.
Description
PTC’s KEPServerEX Versions 6.0 to 6.14.263 are vulnerable to being made to read a recursively defined object that leads to uncontrolled resource consumption. KEPServerEX uses OPC UA, a protocol which defines various object types that can be nested to create complex arrays. It does not implement a check to see if such an object is recursively defined, so an attack could send a maliciously created message that the decoder would try to decode until the stack overflowed and the device crashed.
cpe:2.3:a:kepware:kepserverex:*:*:*:*:*:*:*:*
Show Matching CPE(s) From (including)
6.0.0 Up to (including)
6.14.263
So maybe fixed in 6.15?
*Chris
I did find that they say it is fixed in 6.15. Sorry I did not get back here with that info.
How many versions is the KEPServerEX license good for? If you buy a license for v6.14 can you install anything up to v7?
licenses are renewed on a yearly basis. If the license is not renewed, then the license will only be eligible for versions of the software that were released prior to the expiration date.
*Chris
