In the projects property editor you can add a description and a title but they are not shown in the project tree.
Greetings @Tanquen,
I hope you're doing well.
In KEPServerEX 6.16, you cannot open more than one project at a time.
Regarding naming the project folder, you can indeed give your project folder a specific name. When you save your project, you can choose a custom name for the project file (.opf). This helps in organizing and identifying different projects easily.
You’re correct. In KEPServerEX, while you can add a description and a title in the project’s property editor, these details are not displayed in the project tree. The project tree primarily shows the hierarchical structure of the project components, such as channels, devices, and tags.
How can you name the project folder? Of course you can name the file whatever you like but that doesn't effect the Project Folder name in the tree or anything else. ???
Just seem odd to have a Project folder in the tree when you can only look at one at a time and then to let you add a description and a title but not have seen anywhere, especially the Project folder.
The project folder you are referring to in the KEPServerEX Configuration is a place to access properties that are in the loaded project. This name cannot be changed. The loaded project or .opf file does permit renaming and can be saved or loaded through the "File" tab at the top of the configuration. It is not permitted to view more than one project at a time because the "Runtime" can only connect to one project at a time.
*Chris
