Kepware Tag issue
Hello Everyone,
I am doing POC to integrate the Modbus TCP device data to IOT platform.
Here my challenge was IOT platform not accepting the tag name with "dot" delimiter in Json payload.
so, i need a support or guidance to change the tag hierarchy or delimitator of Tag name in Kepware.
Ex: channel1.device1.voltage -----------> channel1_device1_voltage
Background requirement: I need to read the tag values in IOT platform through MQTT gateway with Advance Template but unfortunately IOT Platform not accepting "dot" in payload variables.
So, is anyone can guide / provide the possible solution to the same.
thanks for your sincere response.
