Kepware connection issue to Rockwell 1756-L72
KV_11492436
7-Bedrock
I've made a Kepware configuration for about 10 Rockwell plc's. But i have an error on one of them. All other 9 are working fine.
It is a 1756-L72 CPU where i have issues to connect with. We've a working connection to another PLC with the same configuration which is working fine.
I don't see an error message in the diagnostic list of Kepware. what is the best way to proceed with this to find a root cause and a solution?
This didn't help.
We made a connection to the webpage of the netwrok card. On that page we could see that the CPU power of the network card was on 100%.
Kepware is the first connection it starts to refuse if this is the case.
Lowering the load on the network card solved my problem.
Maybe the following discussion will be useful - "Integrating KepserverEX 6 with Rockwell Ethernet card in remote rack": https://community.ptc.com/t5/Kepware/Integrating-KepserverEX-6-with-Rockwell-Ethernet-card-in-remote/td-p/953718
This didn't help.
