I have KEPServerEX 6.17.269 installed. I ran Nessus Vulnerability scanner and it appeared that .NET 6.0 is installed on PC. I think that KEPServerEX uses .NET.
The reccomended remediation is to install .NET version 8.0. I wanted to ask if KEPServerEX 6.17.269 is compatible with .NET version 8.0? Is there any page that I could see which versions of .NET is suported by which version of KepServerEx?
HI,
HI,
