U-CON Seek_String hexadecimal
Stephan_G
3-Newcomer
Good evening,
I'm currently working with U-CON (User configurable driver). Telegrams are in hexadecimal. I need to finf a chain of two bytes h90, h90. I can find each byte with "Seek Character" but I have no success by using "Seek String"
Corresponding character of h90 is not available so I cannot use the ASCII character.
I have tried with many format s( ASCII Hex String, Unicode string ..) without success.
Can you please help?
Thank you
Best regards
6 REPLIES 6
AKshara
(To:Stephan_G)
h90 is not a printable ASCII character, the printable ASCII falls between 0x20 to 0x7E in hexadecimal.
Since, Seek Character works on byte-level searching , might have given a success however Seek String is a text-based searching and as I mentioned earlier h90 is a non-printable byte.
Stephan_G
3-Newcomer
(To:AKshara)
Thank you. Indeed h90 (144) is no a printable character but as far I understand from the manual the format "ASCII Hex String" can be used for this case? Do you confirm? If yes, do you know what should be the syntax ?
Sorry, me again. I really need the "Seek String" hunction as I need to find a chain of 2 bytes that can be hA1 h90 or h91 h90 or h90 h90.
From the manual:
Strings encoded as ASCII Hex values.
Example: The string "AB12" would be sent as eight ASCII Hex characters
"AB12" (0x34 0x31 0x34 0x32 0x30 0x31 0x30 0x32).
So I understand that h90 h80 should be encoded by 0x39 0x30 0x39 0x30 . But the format is ASCII Hex
String [hh hh hh...]. So I understand that I should write 39 30 39 30.
I tried but without success
RS_12048754
(To:Stephan_G)
Hi there, could you enable diagnostics on the channel level, then right click on the TXRX section and choose to save as text? this way can see what you're sending and receiving?
The telegram to be decoded is a 10 bytes hexadecimal string:
- Byte #1: Status: h90 for valid data, h91 for reduced performance data, hA1 for invalid data
- Byte#2: Header: h90
- Byte3&4: 16 bit interger data
- Byte5&6: 16 bit interger data
- Byte7&8: 16 bit interger data
- Byte9&19: 16 bit interger data
As you see, this srting as no delimiter. As it is sent continusly, I capture 20 butes and I researche these three possible strings:
- h90 h90
- h91 h90
- hA1 h90
See attached the captures of the messages in hexadecimal and ASCII (ASCII is useless)
See attached the correspnoding Kepware project. For now, I use "Seek character" but it would be much safer to use "Seek string" because any of these 3 hexadecimal values (h90, h91, hA1) could be part of the data.
Here the recorded messages start with h90 h90. This is a chance but I have seen the message shifted and these two character can shift at the middle of the message.
I think "Seek string" can be used with the format "ASCII Hex characters" but I can't find the proper syntax.
Thank you very much for your support
Stephan
RS_12048754
(To:Stephan_G)
Hi sorry for the delay, could you please open a support ticket for this case, the dev team will need to do a code review to see if nonprintable ascii strings can be parsed by the seek string command.
