Unable to write values to AWS topic on MQTT protocol
AnudeepYenduri
7-Bedrock
We have a topic created in AWS environment where we are planning to write values using MQTT client. But the MQTT agent is unable to connect to the topic.
Error : MQTT agent IOT PBM5305 disconnected - reason 'null'
we also referred the PTC article CS378797. But issue is not resolved.
Kindly suggest workaround.
@AnudeepYenduri,
It will more than likely take a Wireshark Capture Analysis to determine any potential additional workarounds other than the resolution details offered in the knowledge base article. I recommend opening a support ticket with the Kepware Team to assist with the Wireshark capture and analysis. Here is a link to the login page where a support ticket can be opened.:
Log In | My Kepware
*Chris
