Writing Value to KEPWare Problem
lzhou-2
2-Explorer
I used OPC DA Server to connect KEPWare to Thingworx, I can read Item values, and I can use KEPWare client to write item value,
but I can not write value to items in Thingworx even if I set item ReadOnly true.
        "BaseType": "INTEGER",
        "Name": "TemperatureUpperLimit",
        "ReadOnly": false,
        "Source": "Channel1.Device1.MyFBox.S7-1500.Item00.温度下限",
        "SourceType": "System.UInt16"
0 REPLIES 0
