Regarding OEE graph
HemalathaMsk
6-Contributor
Regarding OEE graph
What is the Kepware configuration is needed to display OEE graph in Manufacturing app?  Do you have any OPF file, which will give result of OEE, Performance, etc. of a machine?
Hema
The link below has the instruction to setup demo data set. Towards the end of the page you will see a DemoSimulatorPackage.zip for download. It has the opf file.
https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Get-Started/Configuring-the-Apps-with-Demo-Data-Set-and-Simulator
Varathan
slangley
(To:HemalathaMsk)
Hi Hemalatha.
A video is available on the ThingWorx Manufacturing Apps portal which may be able to answer your question.  Login with your PTC Support ID to the following url:  https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Get-Started
Scroll down until you locate the video indicated in the screenshot:
Please let us know if this answers your questions.
--Sharon Langley-Anderson
Varathan
Thanks Varathan
HemalathaMsk
6-Contributor
(To:slangley)
Thanks for your reply, this is what I expected
Hema
