What is the Kepware configuration is needed to display OEE graph in Manufacturing app? Do you have any OPF file, which will give result of OEE, Performance, etc. of a machine?
Hema
The link below has the instruction to setup demo data set. Towards the end of the page you will see a DemoSimulatorPackage.zip for download. It has the opf file.
Varathan
Hi Hemalatha.
A video is available on the ThingWorx Manufacturing Apps portal which may be able to answer your question. Login with your PTC Support ID to the following url: https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Get-Started
Scroll down until you locate the video indicated in the screenshot:
Please let us know if this answers your questions.
--Sharon Langley-Anderson
Varathan
Thanks Varathan
Thanks for your reply, this is what I expected
Hema
