What is ThingWorx connection server ?
suriya
3-Visitor
Hi ,
I'm new for ThingWorx platform , try to self study from the online document .
I have question about the purpose of using the ThingWorx connection server.
"ThingWorx Connection Server provides a server application that allows the connection of remote devices that use the ThingWorx AlwaysOn™ protocol to the instance of ThingWorx platform. This Connection Server handles all message routing to and from devices, providing scalable connectivity to ThingWorx platform."
For the Manufacturing App , it is look like ThingWorx connection server is doing the same task which KEPserver acting.
in the production environment I can choose between ThingWorx connection server or KEPserver to get the data from the remote device .
Is my understanding correct ?
Thank you
The ThingWorx connection server is a concentrator for AlwaysOn agents, its purpose is horizontal scaling.
For example, it is not recommended to directly connect 30 000 AlwaysOn devices onto the ThingWorx platform; you shall interpose a couple of Connection Servers (for example 3 =10 000 devices per connector).
KEPserver can aggregates data from disparate devices and applications. It supports hundreds of different protocols.
4 REPLIES 4
Thank you for the answer .
Another question , can I use KEPserver send the aggregate data from OT device then send that data pass to ThingWorx connection server ?
So the direction of connectivity is ,
OT Device -----> KEPserver -----> ThingWorx connection server ------> ThingWorx MFG app
Regards
What is an OT device and what communication protocol does it use ?
Regards
PS : Note that you probably don't need  a ThingWorx connection server with KEPServer .
Do1
9-Granite
9-Granite
(To:smainente)
An OT device is "Operational Technology" as opposed to an IT (Information Technology) device.
The distinction is important as it deals with devices which have to operation under certain conditions.  Should anything negatively affect these OT devices it could have catastrophic consequences including possibly loss of life.
