4 Axis Milling
  • August 4, 2020
  • 2861 views
I ran a 4 axis tool path a while ago and didn't have any trouble. This was with Creo 2.0, we just switched to Creo 5.0 and now I am having trouble doing it now. I am trying to do a surface mill but it only shows 3 axis available. I went back and looked at the Work center and I have the number of axis's picked to 4. I used this same work center on the other program but it doesn't seem to work the same. I'm not sure what I am doing wrong or if I am missing a setting somewhere else. Can someone give me some hints?
Best answer by KenFarley
When you upgraded to Creo 5 you had to also upgrade the license server. Is it possible that:
(1) Your license server wasn't correctly upgraded and is missing the necessary license data for the 5 axis manufacturing stuff? (Yes, 5 axis, to do true 4 axis you need the 5 axis license)
(2) The name of the license for manufacturing has changed and you aren't looking for it?
(3) When you installed Creo 5 on your machine, you didn't include the manufacturing licenses? I think the default is just to look for the basic program functions, but I could be wrong.
KenFarley21-Topaz IIAnswer
pgf5451-VisitorAuthor
Thanks Ken, I refreshed the licenses and clicked on NC Complete and it seems to be working now. Maybe I just hadn't done the proper refresh. I know the company has been messing with servers and such so maybe it got lost for a while.
Yeah, the license stuff is a tricky beast. I've had more troubles with that than most of the other stuff. Getting a license file that includes all the things we are actually paying for has been a chore, in the past. But a lot of that is because we've been using Pro/E then Creo since 1994...
