I try to output my fixture offsets with a fil macro given by KenFarley on an other topic but when i try :
CIMFIL/ON,SET,OFSETL
OFSTYP=POSTF(6,5)
OFSREG=POSTF(7,5)
IF(OFSTYP.EQ.1)THEN
IF(OFSREG.GE.54.AND.OFSREG.LE.59)THEN
$$CURREG=OFSREG
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2,';'
INSERT/ OFSCMD
ENDIF
ENDIF
CIMFIL/OFF
On my machine file i have :
N0054 ( / SEQUENCE TYPE : PROFILE MILLING);
N0056G90G55;
N0058 G0 Y5.232;
No spaces before G90 and between G90 and G55.
What is the command for output spaces ?
Thanks in advance.
Here's a thing that you should check that might be doing this nonsense:
Tools->NC Post Processor
Pick the option file for the machine you're trying to fix up.
Click on Operator Messages
Make sure Retain spaces in INSERT statements is checked.
When I output text like this to be subsequently output into the code file, I always end the TEXT/ stuff with a
which is comma space single quote dollarsign quote
I think the GPOST interpreter sees that dollarsign as a sort of end-of-line character. It doesn't output it to the file.
Otherwise, I have noticed some weird stuff with spaces in some of the GPOST results. Seems like it is trying to make the code smaller by removing the spaces. I know they are not necessary, the machine strips them all out when I read the programs into memory, but I like them because they make the code infinitely more readable by us poor humans.
See if adding the '$' makes things behave. You might even try ending the line with ';$" since you seem to need a semicolon to end your code lines.
Thanks for your answer. This is what i tried :
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2, ' ; ' , ' $ '
No changes, the $ is not print
N0056G90G55;
N0058 G0 Y5.232;
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2, ' $ '
N0056G90G55$N0058 G0 Y5.232;
N0060 G1 Z-1. F621.;
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2, ' ; $ '
When i pass through a PPRINT commande spaces no longer disappear..
OFSCMD = TEXT/CONVI,OFSREG,2,';$'
TTT = TEXT/ 'G90 G'
INSERT/TTT, OFSCMD
PPRINT/TTT
N0078 ( / SEQUENCE TYPE : PROFILE MILLING);
N0080G90G56;
N0082 (G90 G);
N0084 G0 Y5.232;
It wasn't, obviously!
Thank you very much
Yeah, I'm not a big fan of the Options Editor. It's kind of like being an archeologist sifting through a bunch of stuff to find the one thing I want. Guessing what it's categorized as, then flipping through the different tabs, etc.
Good to know that was it, though. I must have set that years and years ago.
Where is this? In options editor? Obscure FIL code?
It's in the MillCom.txt file. On my computer it is stored in C:\anc\camsys\ncjlibs\com\austinnc\documents\MillCom.txt
When building posts, I just open options file in text editor and directly change the values, so I pretty much always have this text file open.
I like to default set INTCOM(1869) to 1 in options file (add blanks to insert statements) then turn this off as needed in FIL. For example (part of my FIL which handles automatic clamping) P.S. I hate how this forum removes the tab/space formatting making this code look really ugly...
If you want to post code and have it retain its "proper" formatting, you should just use the "</>" or "Insert/Edit Code Sample" to put it in its own little box. That tool uses a monospaced font so code that is indented looks good.
