Adding 'sister tools'...
ptc-1932745
2-Explorer
In Pro-toolmaker, they have the concept of 'sister tools' to denote identical tools than can be swapped in/out after a certain amount of cutting time for die/mold work.
Has anyone been able to find a way to at least add M01 (opp stop) in a rougning or finishing sequence after a specific amount of cuttting time or distance in Pro/NC sequences?
At least with the M01, I can let the machinist know that the inserts need to be flipped, etc...
Is this possible in Vericut? Opti-path maybe? (Full version, not the NC check in Pro-Man)
TIA, (Thanks in Advance),
Christopher Gosnell
TRIGON INC.
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
3 REPLIES 3
I just got a great video tutorial of how to 'customize' an NC sequence to split the sequence, add optional retracts, opstops, etc... THANKS!
Unfortunately, I am using CREO1 NC (not expert machinist) and PTC have 'ribbonized' the interface. I can't find any remnant of a 'customize' command. I will keep looking, and thanks for the repsonse.
Christopher Gosnell
TRIGON INC.
FPD Company
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
could you please share this video tutorial with the list.
tia
Industrial Area - Rodotopi
45500 - Ioannina
Greece
Christopher,
I can help you customize an NC Sequence to add any G or M codes anywhere you want in Creo 1 or Creo 2. It is very easy, but I want you to call me so I can walk you thru it.
Kent Hanson
269-663-5515
