Would anyone know if there a excel sheet or math calculator to input multiaxis cl data goto moves to help verify the post is modified correctly and to make sure the toolpath is process correct.
Ex.
GOTO / 2.14373, 0.51450, 1.50000, $
0.37144886, 0.65651571, 0.65651571
Calculate to something like following and compare results for the machine G code.
G0 X-0.1444 Y-1.6124 B48.965 C60.499
Hi folks,
Sorry for the delay... I forgot about this thread... just remembered about it while parking the car on my garage... go figure 😉
Please find it attached... In the tab "Kinematics math" you are going to find some figures... I commented all cells performing calculations so that you can see the formulas behind the figures...
This is a simple spreadsheet and does not solve math problems related to RTCP / TCPM, both commonly used in multiaxis machining... but it is a start anyway...
Good luck,
Daniel Santos - CAM Support
GE Oil&Gas
