Changing window parameters size in EMX ...
phenriques
Hello
Does anyone know how to change the window size of EMX parameters by default when I want to insert a component?
The window is smaller than it should be ...
I send attached two images; one as it is and the other as it should be. When I want to insert a component it looks like the first image and after changing a parameter the window gets bigger as shown in the second image
Thanks in advance
@phenriques wrote:
Hello
Thanks in advance
if you provide information what Creo and EMX version you are using then I hope @tschneyer will answer you question.
Martin Hanák
Hi ,
I,m using Creo 3.0 M190 with  EMX 10 M011 ...
thanks
Paulo Henriques
Hello phenriques,
This problem was already fixed. Please update to the latest release.
Kind Regards,
Thomas
Kind Regards
Thomas Schneyer
B&W Software GmbH
