Component display in assembly drawings
In my assembly I have a transparent component. (Its acctually a Workpiece in manufacturing.) The problem is that when I create a drawing with this assembly I can see thru this part. I can't see the hidden lines in this part, but I can see all of the lines in the fixture behind it. I would like to have this component display on the drawing as if it was solid. Is there a way to change this in the drawing?
I am using Creo 2.0 M050.
Thanks in advance!
