Creo 3 Volume Rough Problems
Is anyone else all of a sudden having problems with using volume rough in Creo 3.0 M010? I'm doing things the same way I always have and for some reason its giving me fits. If I use a Mill Volume it won't create a toolpath. If I use a Mill Window it will but then when I go to do a Local Milling (Previous Step) it wont create a toolpath. It's nothing that I haven't done before so I'm not sure what is happening.
I got a Roughing toolpath to work how I liked it but then trying to do a Re-Rough it gives me slices I don't want and I can't find a way to remove them. It's actually cutting surfaces that are above my Mill Window.
Thanks in advance.
