Doosan DNM 500ii Sinumerik Post Processor
mbitterwolf
Hi there,
I am currently setting up a 3-Axis DNM Doosan 500ii with a Siemens Sinumerik 828D Control and Creo 3.0 as the CAM software
I am having some issues with the output G-Code concerning the tool Change.
At the moment I get:
N9 M5
N10 T9 M6
N11 S4000 M3
with T(Position Number)
What I Need is:
N9 M5
N10 T="Tool Name" M6
N11 S4000 M3
is there anyone that could help me?
Thank you!
3 REPLIES 3
As an instant solution you can easily substitute T9 by "ENDMILL DIA 10" by example.
On a longer term you have to correct your postprocessor.
We did it for our own DMG machining centre with Siemens 840Dsl.
If you send me a CL file, I can postprocess it for you to show you that it works.
Best regards,
Jef Verheyen,
KU Leuven
Faculty of Industrial Engineering
Campus De Nayer
2860 Sint-Katelijne-Waver
Belgium
Thank you for your fast reply!
With the instant solution I already had my code running but because I am working as a student for a chair of my univerisity they want me to correct the postprocessor.
I tried putting in some fil data:
CIMFIL/ON,PPRINT
$$ Macro to store the tool name in a variable
$$ to re-issue with the tool change
TXT=TEXT/CLW $$ Text of message
TEST=TEXT/'TOOL NAME' $$ Text to test for
OKCOM=INDXF(TXT,TEST)
IF (OKCOM.NE.0) THEN
  $$ This is a tool comment
  MESS=TEXT/OMIT,TXT,1 $$ Omit trailing blank
  COL=TEXT/':'
  COLPOS=INDXF(MESS,COL) $$ position of : in MESS
  LEN=CANF(MESS,1) $$ number of char in MESS
  NMESS=TEXT/RANGE,MESS,COLPOS+1,LEN $$ Extract from : to end
ELSE
  DMY=POSTF(13) $$ Process
ENDIF
CIMFIL/OFF
CIMFIL/ON,LOADTL
IF (OKCOM.EQ.0) THEN
ELSE
  $$ Tool name programmed
  XX=POSTF(2,1,1867,1) $$ no tape output
  DMY=POSTF(13) $$ process tool change
  TNUM=POSTF(7,4) $$ Tool number
  XX=POSTF(2,1,1867,0) $$ re-activate tape output\
  INSERT/'T',TNUM,'M6(',NMESS,')$'
ENDIF
CIMFIL/OFF
But it had some issues with this code and output an error.
Maybe someone can spot my mistake or point me in the right direction?
Kind regards
I have modified your macros little bit.
Notice that Cimfil MACHIN macro was added too.
CIMFIL/ON,PPRINT
  COL=TEXT/':'
  NMESS=TEXT/OMIT,NMESS,3     $$ Omit all spaces
ELSE
ENDIF
CIMFIL/OFF
CIMFIL/ON,LOADTL
ELSE
$$  INSERT/'T',TNUM,'M6(',NMESS,')$'
  INSERT/' T="',NMESS,'" M6$'
  OKCOM=0    $$ Initialization
ENDIF
CIMFIL/OFF
CIMFIL/ON,MACHIN
CIMFIL/OFF
Now, when the tool name is outputed via PPRINT, tool record will be in format: T="TOOL_NAME" M6
When the tool name is NOT outputed via PPRINT, tool record will be in format: T=TOOL_NUMBER M6
Regards
