Working in Creo 10.0 is there anyway to save the draft analysis as a .stp file with the draft analysis colors on the part? I have tried a 3D PDF but have not had any luck.
Hi ZP_9596941
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
