Hello Community,
I am adding an inclined part in EMX Assembly by top-down process.
Part getting added in assembly successfully, but while generating BOM the size calculated by system is rectangular even part is like pin (Circular).
(Actual Size : Dia50 x 300mm - Calculated size: 258 x 258 x80)
Similarly I am assembled a rectangular plate in inclined way by topdown process, wrong size calculated.
(Actual Size : 408x 70x 28.3 mm - Calculated size: 408 x 68 x61)
Please find the attached screen shots.
I used standard Demo data set for trial of EMX assembly.
Looking for response.
You must make a new axial cross in the model.And to mark it see picture.The parts that are formed in the assembly at an angle do it that way.
Thanks for the Solution..!!
Its Working..
