I want to enable the Simscape Multibody Link Creo-Pro/E Plug-In to transfer my 3D modell to simscape. I followed the steps at this link: http://de.mathworks.com/help/physmod/smlink/ug/installing-and-linking-simmechanics-link-software.html
and then this steps: http://de.mathworks.com/help/physmod/smlink/ref/linking-and-unlinking-simmechanics-link-software-with-proengineer.html
I generated a new .pro and a new .dat file.
.dat:
name Simscape Multibody Link
startup dll
exec_file matlabroot\bin\win64\cl_proe2sm.dll
text_dir matlabroot\toolbox\physmod\smlink\cad_systems\proe\text
unicode_encoding false 'got the message without this line too'
end
When i start creo parametric as admin i get this message(my translation):
Creo Toolkit starting mistake
Creo Toolkit registry file C:\Temp\Creo\myprotk.dat:
application 'Simscape Multibody Link'couldn't be started; you can find details in the trail file.
after that i get a second message:
failed to start application 'Simscape Multibody Link'
Text of the trail file:
!trail file version No. 1600
!Creo TM 2.0 (c) 2016 by PTC Inc. All Rights Reserved.
!Exit Logger data:
! Process ID: 3328
! Application: Creo_Parametric
! Start date&time: 2016/09/13 17:38:11
! language: german
! machine type: x86e_win64
! datecode: M110
! Server: NONE
! Workspace: NONE
! traceback file: C:\Program Files\PTC\Creo 2.0\Parametric\bin\traceback.log
!end Exit Logger data.
< 0 0.848593 1220 0 0 716 1366 0 0 768 13
!mem_use INCREASE Blocks 455047, AppSize 51258409, SysSize 61240360
< 0 0.634074 1004 0 0 535 1366 0 0 768 13
< 0 0.634074 904 0 0 535 1366 0 0 768 13
!%CIWillkommen bei Creo Parametric Academic Edition 2.0.
! Message Dialog: Warning
! : Creo Toolkit Registrierungsdatei C:\Temp\Creo\myprotk.dat:
! : Anwendung 'Simscape Multibody Link' konnte nicht gestartet werden; Details finden Sie in der Traildatei.
< 0 0.630519 904 0 0 532 1366 0 0 768 13
~ FocusIn `UI Message Dialog` `ok`
~ Move `UI Message Dialog` `UI Message Dialog` 2 10.112125 10.732725
~ Activate `UI Message Dialog` `ok`
! : Starten von Applikation 'Simscape Multibody Link' fehlgeschlagen.
~ Activate `UI Message Dialog` `UI Message Dialog`
~ Minimize `main_dlg_cur` `main_dlg_cur`
Matlab version: R2016a
Creo Parametric 2.0
I hope you can help me.
Good day Stefan,
Rather than a document, it should be posted as a question within the Creo – this will get the most eyes on it.
Please open a new discussion within Creo and post your question there.
Please let me know if I can be of assistance.
Best,
Toby
