OK so I can make 3+2 move only but after rotation statement gets printed 4 times!. Anyone know how?
Difficult to say without experimenting but maybe it's outputting a bunch of repeated motion commands? If it were me I'd look in either:
Applications->NC Post Processor
Then Motion, see if "Output the repeat point" is set, maybe try "Do not output the repeat point".
Check the other settings for motion and see if anything is weird.
Also maybe check the FIL editor and see if there is some weirdness in there. I've never messed around with 3+2 or 5-axis, just a wee bit of 4-axis machining. Is it unlocking-moving-locking the axis every time? That would be very annoying. Hand editing it out would not be nice, either, because I know I would forget at least once...
I did make the changes still is the problem. Also see the document for limiting B Axis in fil programming. It doesn't work either not sure what I am missing!!.
CL DATA
PPRINT / CUT FEEDRATE & UNITS : 20.100000 IPM
PPRINT / ARC FEEDRATE & UNITS : N/A
PPRINT / FREE FEEDRATE & UNITS : N/A
PPRINT / RETRACT FEEDRATE & UNITS : N/A
PPRINT / PLUNGE FEEDRATE & UNITS : N/A
PPRINT / RETRACT HEIGHT : 0.500000
PPRINT / TOOL NAME : T00029
PPRINT / TOOL_TYPE : END MILL
PPRINT / CUTTER_DIAM : 0.125000
LIMIT / BAXIS, -35, 110
LOADTL / 29
$$-> CUTTER / 0.125000
$$-> CSYS / 1.0000000000, 0.0000000000, 0.0000000000, 0.0000000000, $
0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000, $
0.0000000000, 0.0000000000, 1.0000000000, 0.0000000000
MULTAX / ON
i GOT THIS WORKING.
