How to enable the creo additive manufacturing printgroup command
SP_10210577
Hello, I'm trying to make a stack in Creo, but the button to start printing is disabled.
USB is currently connected.
Is it a problem that requires a separate license? Or is there another problem?
Thank you.
2 REPLIES 2
tbraxton
(To:SP_10210577)
Creo Additive Manufacturing Extension (AMX) extension is an additional license. If you do not have AMX this article explains the free functions.
https://www.ptc.com/en/blogs/cad/additive-manufacturing-creo-base-package
Involute Development, LLC
Consulting Engineers
Thank you for your reply.
I checked and I had a license. Is there any other reason why the button was disabled?
Can I connect the printer only through the network?
