Machining a groove in a cylindrical part
- October 30, 2014
- 1 reply
- 8526 views
Hi All,
Today's question is this:
I need to cut (machine) a goorve about the circumfernce of a round part, a cylinder. It's a zig-zag cut, that repeats twice around the part. The width of the cut needs to be constant, as well as the depth. The inner points of the zig zag need to be sharp. Ideally, I envision the part being chucked in a lathe, then the end mill would drop down & cut the groove.
The attemp shown is done with the graph sweep path, but the feature that sweeps remains constant to the part axis, it's not 'normal' to the intended cutting path, which is what I'm after. I'm assuming there is a simple way to 1) make the path I want to cut along (Assumign the graph path I created above), and 2) then sweep a solid feature (the end mill / a cylindrical shape) along the path to remove the material. this feature wodu be tangent to the surface of the cylinder..
Any ideas?
