Modifying H# in Post Output
JasonPensack
7-Bedrock
I am trying to create a post for a machine that requires all H#'s to be H1 and all D#'s to be D02. The way I do this now is to put the 1 for the H# in the Tool Offset in the Tools Setup. And for the D02 I put it in the Cutcom Register for each sequence. This becomes a problem when I want to change the job to another machine. I have to go through each tool and each sequence which is very time consuming.
I can get the D#'s to work by unchecking the box in Gpost where it says "Output the tool number as the diameter offset when not specified." This outputs all of the D#'s as D0 and then I use a fil command to change it to D02.
$$ Replace D0 with D02
T4 = TEXT/'D0'
T5 = TEXT/'D02'
REPLAC/T4,T5
There is a similar check box in the Tool Change Sequence tab in Gpost but instead of outputting the H0 it does not output the G43H# line at all. Is there a way I can get the G43H# line to output with this unchecked? Or is there a way to write a REPLAC command where I can replace a range of numbers (H1 thru H99) with H1? I guess worst case scenario I could write the REPLAC command above individually for every possible H#, but I would rather keep my FIL as clean as possible.
I am using CREO 2.0 M070
Figured it out.....
I have a Cimfil routine to catch the first GOTO move after a toolchange and add a G90 to it, which also outputs the first "Z" move on the next line with the G43 and the H#. Before it executes this CL command, I can override the INTCOM value for 1492 (which is the Length Offset Number) to 1. Here is how it looks....
CIMFIL/ON,5,5 $$CATCH THE GOTO POINTS
DMY=POSTF(20) $$SAVE THE CURRENT CL RECORD
IF(LTSW.EQ.1)THEN $$FIRST MOVE AFTER LOADTL
LTSW=0 $$RESET THE LOADTL SWITCH
ENDIF
PREFUN/90,NEXT $$OUTPUT G90 WITH NEXT BLOCK
DMY=POSTF(2,1,1942,1) $$Set INTCOM value for H# to 1
INSERT/'M56H1D2$'
DMY=POSTF(21) $$RELOAD THE SAVED CL RECORD
DMY=POSTF(13) $$EXECUTE THE CURRENT CL RECORD
DMY=POSTF(26,5,5,0) $$TURN OFF THIS CIMFIL/ON,5,5 ROUTINE
CIMFIL/OFF
It will output G43 Z### H1 for every tool.
Figured it out.....
ENDIF
INSERT/'M56H1D2$'
CIMFIL/OFF
