Postprocessor LinuxCNC
MaikTheBike
Does somebody know, where to find a postprocessor for LinuxCNC for milling ?
Somewhere on the internet I read, that it uses RS-274NGC -code. So maybe there is a postprocessor that can be used ?
And if not, do you know a good tutorial on how to create such a postprocessor ?
BR84
(To:MaikTheBike)
Dear MaikTheBike,
there is no easy solution to your question.
In my case, I have gone through a g-code that is readable by my machine,
found post-processor that's output is similar to what is needed, and refine it in NC post-processor application till you are satisfied with the results.
You will not succeed if you only have an anti-advertising of cam product called expert machinist. Not only it extremely being extremely unstable, and limited in functions - it doesn't allow to select post-processor.
please visit this page - you will find their links to numerous postprocessors, something will fit your needs.
https://www.ptc.com/pt/support/article/cs54723
Have a good rest of the day.
Regards
